Hello,
I recently tried to crossfire two r9 280x's in my system and figured i would update my drivers. Heres where the problems start.
Catalyst 15.7.1 will not install past the Microsoft visual c++ 2012 redistributable stage. Gives me installation error message continues to install Raptr
I followed troubleshooting steps on guru3d, Microsoft support, and AMD support to use DDU to wipe all video drivers from the computer and clean install.
Same issues. However, now i cannot install any windows updates even with windows installer settings turned on.
So now im stuck with two 280x's in my PC that might as well be paperweights.
I need some kind of help at least getting some kind of drivers installed so i can use them.
Before you ask, I ran everything as admin. I ran DDU in safe mode. I created a new admin account and ran all as admin again.
I believe the problem lies in the Microsoft Visual c++ redistributable installer. However all searches give me download links for windows 8.1 and lower. Went to Programs and Features and enabled everything I could as well.
Thanks.
I build PCs as a hobby.
https://linustechtips.com/topic/462290-catalyst-control-center-will-not-install/
