issue with that is I get a 404
What are you making the site with?
EDIT: Its all working for me just need to change config to allow the site to access the CSS and such
https://linustechtips.com/topic/462274-help-with-a-forums/#findComment-6203881
It installed but the it kept redirecting me to a certain website and I couldn't even login to the thing. The CSS wasn't working for it either.
You did set the login info when installing.. right?
https://linustechtips.com/topic/462274-help-with-a-forums/#findComment-6203929
Yeah I set everything up. It kept redirecting me to an myatt website. also it didn't even go through the install process with me. It kept going straight to the site. It didn't even let me setup the database
https://linustechtips.com/topic/462274-help-with-a-forums/#findComment-6203933
myatt? whats that?
https://linustechtips.com/topic/462274-help-with-a-forums/#findComment-6203945
