Someone's going to recommend an AMD GPU because of that budget but nvidia's streaming features are pretty cool IMO... maybe a 960?
Pretty hard . . . This, unless you want to go AMD CPU
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($175.88 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard ($42.89 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.88 @ OutletPC)
Video Card: MSI Radeon R7 370 2GB Video Card ($134.98 @ SuperBiiz)
Case: Corsair 100R ATX Mid Tower Case ($49.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($44.99 @ Newegg)
Total: $538.60
Generated by PCPartPicker 2015-10-05 23:55 EDT-0400
Total: $538.60
What would amd look like? Better or potentially worse
Cheaper, but probably worse.
$500 isn't really a lot to do a high end machine with
$500 is enough for a decent bang for the buck gaming system, not a decent machine that can "game and stream and record" then "video edit and render" with any sort of proficiency at anything!
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
Hey! I really wanna build a computer than can run some higher end games and stream hd on twitch, but I cant really spend too much money on it... My max would be about 500 $, any geniuses that can help me out?  :)  :)
save up some more
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
