Gigabyte R9 290X 4GB for $351 CAD Refurbished Worth it? or should I wait?
My specs are:
Case Corsair 250D mitx
CPU i5 4690k
MOBO: Asus Maximus VI Impact
SSD intel 250G/HDD 1TB
RAM 8gb Corsair (got off a friend)
GPU xfx HD 6870 1gb (borrowing off a friend till I get one)
https://linustechtips.com/topic/461571-help-with-buying-new-gpu/
The 390 brand new starts at less than that and it has close enough performance (sits in between the 290 and 290x) but well it's brand new, not refurb
http://pcpartpicker.com/parts/video-card/#c=311&sort=a8&page=1
Current Rig
https://linustechtips.com/topic/461571-help-with-buying-new-gpu/#findComment-6193571
Forgot to clarify though... $351 CAD not USD.
ATM the Canadian dollar is significantly lower than that of USD... and its affecting the prices of GPU's quite drastically.
Average price for a GTX 970 is around $400 CAD.
https://ca.pcpartpicker.com/parts/video-card/#c=186&sort=a8&page=1
So the r9 290x will be $50 cheaper... not sure if its worth it to spend $50 more and get a new $970?
Still not sure what to go with.
https://linustechtips.com/topic/461571-help-with-buying-new-gpu/#findComment-6193674
