I currently have an i5 650 with a gt 240. I was looking to upgrade my gpu to a gt 640, either the 1 or 2g gddr5 models.
I take it you aren't in america?
what's your total budget for upgrading?
https://linustechtips.com/topic/461184-help-with-my-build/#findComment-6188997
