My Sennheiser game zero came in the mail yesterday and today I was going to use it. However the audio works fine but the mic is not.
I plugged the jack into this one since the first 2 are mic and microphone. Did I needed to buy the Sennheiser PCV 05 Combo Audio Adapter for it to recognize my headset in order for the microphone to work? It will show this when i plug the headset jack into the laptop (MSI GT70) and when I go to audacity it doesn't show an option for my headset just the built in laptop microphone, and when I used the StarTech MUYHSFMM 3.5mm 4 Pin to 2x3 Pin 3.5mm Headset Splitter Adapter the mic would work fine but the sound quality will sound like a fan is blowing in my mic
https://linustechtips.com/topic/460705-sennheiser-game-zero-mic-help/
but when i used my StarTech MUYHSFMM 3.5mm 4 Pin to 2x3 Pin 3.5mm Headset Splitter Adapter and plug it in the mic and audio jack it will recongize the headset, but the microphone had a really bad static and not sure if it's the splitter and using the wrong one or what
Don't use a splitter
They suck
Just plug the micrphone into mic jack and headset to headphone jack
Insert   Dank   Signature   Here.
From what I can see on that image (and on this one: http://www.unlockpwd.com/wp-content/uploads/2014/11/MSI-GT70-2QD-2433XFR-Dominator-3.jpg), you are sticking it to wrong jack. The heapdhones are the first one and mic is second one (from back, you are sticking it to 4th one).
