Does need for speed on pc have controller support, i have a ps3 and a xbox 360 controller and some random madcatz pathetic thing.
Listen if you care.
https://linustechtips.com/topic/45933-need-for-speed-controller-support/
They should. The latest ones are console ports anyway. If not, there's always xpadder :)
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
I have used a Xbox 360 controller on all the Need For Speed games since Most Wanted.
Core I7 3930K 4.6ghz, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 780Ti SLI, Corsair Force 3 240Gb SSD, Asus Xonar DX, Killer Xeno Pro, Phobya Easy Bench V3, Phobya Extreme Nova 1080
