How do I enable 'Previous Versions'?
Currently using Windows 10 Pro installed on an SSD with two HDDs as storage.
I was editing a photo and accidentally hit save instead of save as. Went to restore it to the previous version but it says there isn't one.
I think I read somewhere it has to do with system restore but that is enabled.
Do I need to enable it on my HDDs as well in order for it to keep a copy? I don't save anything to the SSD.
The only time incorrectly is spelled incorrectly is when it is spelled incorrectly.
https://linustechtips.com/topic/459313-how-do-i-enable-previous-versions/
try this
http://windows.microsoft.com/en-us/windows/previous-versions-files-faq#1TC=windows-7
It's called File History (search it in the start menu and you can then configure it)
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
"System protection might not be turned on for the drive those files are stored on. If system protection is not turned on, Windows can't create previous versions."
Yep, thought as much.
Thanks!
File history works but I don't have a donor drive to store it on.
