Hi, Nandit from New Delhi , India
i've got 20k rupees for a new build which isnt much , and also if i sell my previous components , i may get 3-4k more - the total comes in 23k minimum
now, i want an amd processor ( as i have an amd board) , a graphic card , a case and a psu
i have settled for 2 options after wandering the web for days
1.i'm getting a 7870+corsair vs650+dragon chaos gaming mouse-and a cooler master tx3 , all of which are used for 13k .. and a fx 8120 processor (used ) which i got for about 6 k , and 4-5k for a  new case.
2.i'm getting a r9 280x for 15k (used) and buy a processor (used ) for about 3.5k (i'm getting a phenom 2 955 )... and buy a shitty case and a vs450 (used) which i'm getting for about 4k total (case and psu)
 and i game whenever i have a chance (gaming is love , gaming is life)
i'm very confused, i won't be able to upgrade the pc for almost 2-3 years after this
and no , i cant pool in more money,
also , all the things i've mentioned that are used have some warranty with them ...
thank you in advance for the advice guys  :)
https://linustechtips.com/topic/458988-expert-advice-needed-pls-help/
can you please advise me a good case? for 3-4 k rupees .. also .. sorry for reposting, no one was replying , and i need to upgrade urgently .. thank you :P
Unfortunately I don't know any indian prices. The nzxt source 210 should do the job just fine, and come in at 2k rupees if they keep the us pricing.
sudo chmod -R 000 /*
Corsair VS are crap and should NOT be used in a gaming build unless you want fire in your case.
please explain... :( 2 of my friends have been using vs psus for quite a while now without any issues
and my config is not that demanding too ...  what shouldi get now?
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
Don't buy tier 4 ot 5 - even some tier 3 are questionable.
i have no idea what tiers are in psus , please elaborate .)
Tier 1 are the best, most solid and top-quality units
Tier 2 are very good units, usually geared towards lower budgets and offer great quality and reliability
Tier 3 are decent units - not good for OCing or heavy loads but won't burn out usually
Tier 4 are lackluster units, usually poor quality, bad and cheap components, mediocre build quality. Some can kill systems.
Tier 5 are fire hazards
Hi , got a seasonic s12 ii 520 w PSU , good enough yeah ? And a bitfenix merc Alfa , both for 5.6k total , now I've got 6 k for a processor , please advice me one ( new or used ) for an and board
