i ve read everywhere, that intel cpu's are much better than amd, so im going to get an intel cpu, it also leaves room for upgrades whereas a fx 8350 doesnt.
i need a motherboard under £80 ($120) which is very reliable and can overclock. i will probably gat a i5 4460, this cannot overclock i know, but my future cpu might be able too.
suggestions will be muchly appreciated!
https://linustechtips.com/topic/457322-help-with-motherboard/
i need a motherboard under £80 which is very reliable and can overclock. i will probably gat a i5 4460, this cannot overclock i know, but my future cpu might be able too.
http://uk.pcpartpicker.com/part/gigabyte-motherboard-gaz97d3h
https://linustechtips.com/topic/457322-help-with-motherboard/#findComment-6136986
If you want a Z97 motherboard you're going to be spending over 100usd for a good one. At that point it comes down to the rest of your build as each has strengths and weaknesses.
£* You can easily get a MSI Z97 Gaming 3 or MSI SLI krait in that bracket
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/457322-help-with-motherboard/#findComment-6137016
        Setup
https://linustechtips.com/topic/457322-help-with-motherboard/#findComment-6137021
To be fair, OP hasn't stated if they will need a board that supports SLI or Crossfire.
But here's one that supports both.
http://uk.pcpartpicker.com/part/msi-motherboard-z97sslikraitedition
85 euros is about a hundred bucks. I wouldn't get a Z97 board without SLI support because the point of getting a Z97 board with a locked CPU is adaptability. So for a few extra bucks if you want to go with duel GPUs you can.
If anyone asks you never saw me.
https://linustechtips.com/topic/457322-help-with-motherboard/#findComment-6137081
