Hello LTT Community,
So I finally got my third ultrawide today, and I'm trying to get NVSurround to work correctly.
The issues I'm having are this..
Both my monitors are 2560 x 1080 @ 60hz
Monitor 1 & 3 (Left and Right) are plugged in VIA DVI-D
Monitor 2 is plugged in VIA  HDMI.
Graphics Cards: 2x GTX 970 STRIX
Driver Version: 355.98
OS: Windows 10 Pro
When setting up NVSurround my only available resolution is 5760x1080 which is the resolution of 2 monitors, not 3 (3 would be 7,680x1080)
Does anyone know how to get this to work?
Thanks.
https://linustechtips.com/topic/457233-nvidia-surround-using-wrong-resolution/
OS: Windows 10 Pro
Thanks.
Is your HDMI monitor working at its native resolution ?
Also, i dont know if tat's right but Surround plays better with 2dvi and one DP
Does the Surround Setup detect all monitors?
Yes, it gives me all three monitors (shows 3 in the display area labeled 1,2,3), and has all 3 checked.
Yes, it's running its native resolution, and my monitor only supports dual hdmi (dual input for splitscreen LG 25UM57 with 2 LG 25UM65)
Wait, so you have two different monitors?
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
But those should all be 2560x1080, so it should theoreticly work with surround, or shouldn't it?
They should. Could you maybe post a picture of the part that goes wrong?
Sorry for the slow replies, at work at the moment.
Yes, they are 2 different monitors, but the same spec/resolution (LG discontinued the 25UM65's)
They are all 2560x1080 @ 60Hz
Heres the pictures;
