So, im gonna paint my fan rings from my af120's (again) but im wondering. Will the result of the painting look different from painting on a blue ring to a white ring?
Thanks!
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/456976-fan-ring-painting/
Thanks!
Depends on the paint. Plastidip should do fine.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6132852
Thanks!
The colored rings are actually made of plastic of that color but if you use matte type spray paint or plasti-dip it will give a very similar effect.
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6132903
Ive tried plastidip. Didnt work out well. I have bought some normal orange spraypaint instead
Built  Not Bought
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6133036
Im using something a bit glossy while still being a little matte. The paint is orange, will it affect the result, between using the blue or white ring?
Built  Not Bought
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6133042
It wouldn't really make a difference with good quality paint, white might require fewer coats, I think I remember you mentioning this where the plasti-dip etched into the old rings and wasn't very durable.
I'd probably want to roughen up the surfaces first before painting to ensure good adhesion or apply a primer, I have a writeup that goes over it more in depth under General Painting:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6133064
I dont know What great quality paint is. The one im using is mtn 94 spraypaint.
Built  Not Bought
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6133108
Oh that Montana's stuff is really good, very heavy on the pigment so two coats at most and you should be good  :D
Thats good, so I can also use the blue rings, but maybe just with an extra coat?
Built  Not Bought
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6133127
If it was bad paint maybe a extra coat but shouldn't really be a big difference with whichever ring you paint with the stuff you got.
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6133138
Thank You so Much, now my next project is to get some rings! :D the blue ones i painted with the orange plastidip was the last ones i had :D
Built  Not Bought
https://linustechtips.com/topic/456976-fan-ring-painting/#findComment-6133153
