First PC Custom Build
Get the cheapest 1080p IPS display, there's no reason to spend that much on that display
Do you really need a blu ray drive?
Here'd be my suggestion anyways, it's open to crossfire in the future, and has some room for whatever else you want, otherwise don't forget a microphone and headphones
The case is just my personal preference, but it has Hot Swap Bays if you want to archive your footage.
http://pcpartpicker.com/p/8b69D3
PCPartPicker part list: http://pcpartpicker.com/p/8b69D3
Price breakdown by merchant: http://pcpartpicker.com/p/8b69D3/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($325.99 @ B&H)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard ($169.99 @ Newegg)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory ($47.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card ($334.98 @ Newegg)
Case: Cooler Master HAF XB EVO ATX Desktop Case ($86.99 @ Amazon)
Power Supply: Rosewill 1050W 80+ Gold Certified Fully-Modular ATX Power Supply ($139.99 @ Newegg)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor ($109.99 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($26.99 @ NCIX US)
Total: $1322.79
Generated by PCPartPicker 2015-09-28 01:36 EDT-0400
looks pretty much the same any reasoning behind you selection over mine, beside personal preference?
thanks with the monitor suggestion.
