I need help with GPUs
Go to solution Solved by Br3tt96,
Some sort of EVGA 980ti.
If that's too high get a Geforce 980.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/455997-i-need-help-with-gpus/#findComment-6119266
980TI would be your best bet for that price point
but that would be slightly overkill for 1080p
CPU: Intel Core I5 4590 | GPU: EVGA GTX 970 SSC | Mobo: ASRock Fatality H97 Performance | Ram: HyperX Fury 8gb 1866 | SSD: Intel 520 series 240 GB | HDD: WD Blue 1TB | Case: Aerocool DS 200 red/black | Cooler: Coolermaster Hyper 212X | PSU: Antec High Current Gamer 620w | Monitor: AOC i2367fh & old HP | OS: Windowws 7
https://linustechtips.com/topic/455997-i-need-help-with-gpus/#findComment-6119279
I will say R9 390/X
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/455997-i-need-help-with-gpus/#findComment-6119304
