140mm fan options
Solved by tomas710,
As a side note, what's a decent 120mm static pressure optimised fan? I'd rather not get a Noctua for that one as it will be sitting in a second build which will be cheaper.
My slight OCD also prevents me from putting better parts in my secondary PC over my main rig, so NF-F12 is out. :')
Well, NF-P12s are cheaper. I have Phanteks MP and they work great, so do AP123s
http://www.amazon.com/gp/product/B00OP2PUB8?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s01
A good cheaper options if Cooler Master Silencio FP, i bought one just to check it out since it was like 6-7 dollars and they are very quiet high SP fans. Not sure they are available in the US but i'll leave a british link cause....idk
