Fan controller suggestions.
I want a fan controller that goes onto a single 5.25 bay or a single PCI-E slot. I have 5 fans, 2 AP 121 on my h100 and 3 Fractal design r2 140mm fans.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/4527-fan-controller-suggestions/
The Hydra Pro or the Recon by Bitfenix can control up to 5 fans.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/4527-fan-controller-suggestions/#findComment-53799
Should i get the Hydra Pro or the Fractal Design Adjust 108, I really only need 5 Controllers. so which looks better ? warrenty? quality?
https://linustechtips.com/topic/4527-fan-controller-suggestions/#findComment-55449
The Fractal Design Adjust 108 can deliver up to 36W while the Hydra Pro only delivers 30W. There is a jumper on the Fractal Design Adjust 108 for adjusting the intensity of the LED levels unlike the Hydra Pro which only allows you to turn them off or on. I would go for the Fractal Design Adjust 108 because it has better features than the Hydra Pro and it has brushed aluminium which looks great.
Sources:
Fractal Design Adjust 108: http://www.tweaktown.com/reviews/5095/fractal_design_adjust_108_fan_controller_review/index2.html
Hydra Pro:http://www.tweaktown.com/reviews/4904/bitfenix_hydra_pro_fan_and_led_controller_review/index2.html
https://linustechtips.com/topic/4527-fan-controller-suggestions/#findComment-55491
