Hi guys
So I got my cards up to 8ghz effective but I don't no if the msi 980tis have active cram cooling
My temps didn't increase and both cards are stable
Will this effect the life or the cards?
Should I back it down a bit ?
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/452505-memory-speed-over-clock/
No buddy you should be fine. Most GTX 980 Ti's seem to be reaching around 8GHz on their memory clocks. Without touching the core clock I got mine safely to 8.4GHz but had to back it down to 7.4GHz to get my core clock up to 1500+MHz stable.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/452505-memory-speed-over-clock/#findComment-6068526
