I will be doing my first desktop build in a few days and I want to do a test boot before I install everything in the case. I have the Kraken X61 AIO cooler and my i5-6600K doesn't come with a stock cooler. Do I need to mount the X61 for the test boot? Once it is installed I am guessing that it is best to not take it off as I would have to reapply thermal paste?
| Intel i5-6600K | NZXT Kraken X61 | MSI GTX 980TI | NZXT Kraken X41 | ASUS MAXIMUS VIII Hero Corsair Vengeance DDR4-3000 16GB |
                |Samsung 850 EVO 250GB | WD Blue 1TB | EVGA SuperNova G2 850W | Fractal Design Define S |
https://linustechtips.com/topic/452293-test-boot-with-aio-cooler/
I will be doing my first desktop build in a few days and I want to do a test boot before I install everything in the case. I have the Kraken X61 AIO cooler and my i5-6600K doesn't come with a stock cooler. So do I just install the X61 before I boot up and then remove it when I install it in the case?
Test it outside the case before installing it in the case, make sure you dont put the side panel on too (for good luck)
I did a test boot on my brand new Skylake build with the mobo installed since installing an aftermarket aircooler is kind of a pain outside the case. Worked out well enough.
EDIT: Where you do your test boot only affects how much of a pain it'll be pulling stuff out if you've got parts that are dead on arrival.
Arcturus(log here): Intel Core i7 6700K // MSI 980 Ti Gaming 6G(1454/1995) // Kingston HyperX Fury DDR4 2133MHz 16GB //  MSI XPower Gaming Titanium Edition // Samsung 850 EVO 500GB // WD Black 2TB // Corsair 760T // Corsair RM850i
Maybe I wasn't clear enough...I am asking if I need to mount the X61 for the test boot? I am guessing that once it is on there I can't remove it without reapplying thermal paste again...
You will have to mount it.
generally for things like this a test boot, you can remove it and replace it without a problem (w/o changing the thermal paste). But if its one thats been used for a month or two, You'd want to re-apply the thermal paste
Okay great, it is a brand new build.
