They look pretty much the same to me. Same features mostly, except that the Gigabyte has 2 "M.2" slots, that you probably won't use, but ASRock has 12 12k power phase design, which I believe is better than Gigabytes 10k (I didn't find how much phases Gigabyte has). So I would recommend ASrock.
CPU: Ryzen 5 2600, MOBO: MSI Tomahawk B450, RAM: Corsair Vengeance RGB 3000 (2x8 GB), GPU: MSI RTX 2080 Gaming-X Trio, CPU Cooler: Noctua NH-U12S, PSU: Corsair RM 650, HDD: WD Blue 1TB, SSD: Samsung 860 ECO 500GB, CASE: Fractal Design Meshify C
https://linustechtips.com/topic/451731-need-some-help/#findComment-6056567
Okey , ty :)
https://linustechtips.com/topic/451731-need-some-help/#findComment-6071320
