but the MoBo comes with LAN...
Wait, LAN and wifi not the same?
you mean RJ45 Cable ? yes, but LAN is a Connection Type it stands for Local Area Network the computer that has the same Router Connected
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
LAN basically refers to the wired connection in general (because there are multiple kinds of possible wired connections but all create a LAN)
Wi-Fi or WLAN (Wireless local area network) is  different from LAN.
The Term Wi-Fi is a nonsense brand name for IEEE 802.11b Direct Sequence and is a play on the Term "Hi-Fi" meaning high fidelity, but literally has nothing to do with it (Hi-fi) other than that.
Wi-Fi requires a wireless internet card on a desktop, or a small wifi module built into the board, or a laptop.
Troubleshooting a pc will make you believe in gremlins.
--Thread killer--
