LINUX STUFF HELP PLZ
Go to solution Solved by omniomi,
# ls -l
Will give you the output in a long list format.
Personally though I generally use:
# ls -alhF
In Ubuntu the alias ll is mapped to ls -alF by default, I modified it to add the -h... So from the prompt I just run:
# ll
And you get:
root@omn:/var# lltotal 56Kdrwxr-xr-x 14 root root   4.0K Jun 29 14:35 ./drwxr-xr-x 22 root root   4.0K May  7 17:20 ../drwxr-xr-x  2 root root   4.0K Aug 22 06:33 backups/drwxr-xr-x 10 root root   4.0K May  7 17:20 cache/drwxrwxrwt  2 root root   4.0K Apr 20  2014 crash/drwxr-xr-x 39 root root   4.0K May  8 11:01 lib/drwxrwsr-x  2 root staff  4.0K Apr 10  2014 local/drwxrwxrwt  3 root root   4.0K May  7 23:25 lock/drwxrwxr-x 14 root syslog 4.0K Sep 16 06:32 log/drwxrwsrwt  2 root mail   4.0K Apr 16  2014 mail/drwxr-xr-x  2 root root   4.0K Apr 16  2014 opt/lrwxrwxrwx  1 root root      4 Apr 20  2014 run -> /run/drwxr-xr-x  7 root root   4.0K May  8 11:00 spool/drwxrwxrwt  2 root root   4.0K Jul  2 16:25 tmp/drwxr-xr-x  8 root root   4.0K Jul  2 10:05 www/root@omn:/var# root@omn:/var# root@omn:/var# type llll is aliased to `ls -alhF'
To set an alias in bash:
# alias ll="ls -alhF"
To make it permanent you need to add it to your ~/.bashrc file. Ie:
# some more ls aliasesalias ll='ls -alhF'alias la='ls -A'alias l='ls -CF'
Note: as someone mentioned -1 gives you a single column list but without the details. Just the file/folder names.
no when you type ls that give you a list of the file they are in the folder and is like a form of a "colone" but i want it in page ( sorry im french)
I guess you're trying to get it all in one column instead of multiple? In that case use:
ls -1
If you want to pipe the content to something else, ls automatically writes one file/dir per line when piping.
https://linustechtips.com/topic/450716-linux-stuff-help-plz/#findComment-6044471
# ls -l
# ls -alhF
# ll
And you get:
https://linustechtips.com/topic/450716-linux-stuff-help-plz/#findComment-6045879
# ls -l
# ls -alhF
# ll
And you get:
i have found the command i wanted : ls -l | more
https://linustechtips.com/topic/450716-linux-stuff-help-plz/#findComment-6046167
