Raspberry pi web control
First off I don't think you can do that with an .html file. You would need a .php one or atleast a javascript in the html that then calls the python script. Don't quote me though since I personally have trouble with these things haha, but I think that is how you need to start.
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6021415
well, at least thanks for the reply, and i tried ajax, but that didn't work...
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6021445
How does the code look like? I could try to help you, can't garantue I will solve it though
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6021456
I threw it in the garbage, but if you type in tinkernut in YouTube you'll probably find the video that I followed...
Well you could have tried to do this in php. It should run the python file, if I'm right
<html><body><?exec ("helloworld.py");?></body></html>
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6021468
I don't have my pi on hand, but I'll try
Yeah I could have tried if I had any python scripts hah. My pi should be running a apache server with all plugins and such.
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6021474
I don't have my pi on hand, but I'll try, and how do I make it on a button press?
Have an invisible iframe on the page, and when the button is pressed, it could use JavaScript to change the iframe location to the PHP page which then runs the python script.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6021909
about plugins, will I need any for this?
You will need it enabled for php, but really if you have a web server everything important should be included
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6022229
Why not write a service that responds to GET requests with python in the first place? Then send ajax requests and do whatever, if you can't get direct requests to client, then do the requests from php. I remember I did that once to circumvent CORS and put an external api functions into my web page.
https://linustechtips.com/topic/449083-raspberry-pi-web-control/#findComment-6025100
