Cable connection
Go to solution Solved by TheGamingBarrel,
http://www.msi.com/support/mb/Z170-KRAIT-GAMING.html#down-driver&Win10%2064
Download "On Board LAN Driver" from there and you will be all good to go
just started my computer for the first time and installed windows 10. I cannot connect my computer to router using cable. Does anyone know how to do it?
It said that there is no networking hardware detected.
You will need to install drivers for your motherboard's Ethernet controller. These can be found on the manufacturer's website or on a disc that came with your motherboard.
https://linustechtips.com/topic/448036-cable-connection/#findComment-6007566
You don't have drivers for it. Find your motherboard model on the manufacturer's website and get the drivers from the support/downloads sections or get the CD that came with the motherboard (if you have a DVD drive) and install the drivers from there and let Windows install the most recent then try to connect to the internet.
Regards Elias N Martinez. | Graphic and motion design are my jobs. 3D modeling is my hobby. I do what I enjoy.  Skype: eliasnmartinez1 (please state that you are coming from LTT)
https://linustechtips.com/topic/448036-cable-connection/#findComment-6007576
You need to install your LAN Driver. What motherboard do you have?
I have a msi z170 krait gaming motherboard.
My motherboard didnt come with any discs
https://linustechtips.com/topic/448036-cable-connection/#findComment-6007584
i only got a disc with my msi gpu but not motherboard
https://linustechtips.com/topic/448036-cable-connection/#findComment-6007602
If you have an android phone you can go to MSI's website on that, download the driver package, and transfer it to your computer over a USB cable.
Otherwise you'll just have to use another computer with internet, and a flash drive.
https://linustechtips.com/topic/448036-cable-connection/#findComment-6007615
^^ what he said.
https://linustechtips.com/topic/448036-cable-connection/#findComment-6007626
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/448036-cable-connection/#findComment-6007731
