[Linux] RDIFF connection Issues
Solved by MayContainVennom,
Issue solved
Some of the guides recomend that you don't give the account that access's the server a shell which basically stops RDIFF from running. I knew it would be something that simple
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
play_circle_filled
Latest From ShortCircuit:
