Hi everyone,
I want a strong wifi signal in my basement, I initially wanted to get a lan cable into the basement but now for reasons itss not going to work. I barely get any wifi signal in the basement because of the distance, what would be my best option to boost signal, wifi extenders ?
Thanks in advance
https://linustechtips.com/topic/446301-internet-basement-problems/
A second router acting as an AP (Access Point) or a signal repeater.
Should be placed on the bottom floor (I assume it's a house) in the general area of the basement. If the floor isn't too thick you should be fine then
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
powerline adapters are the answer to your question
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
  • 2 weeks later...
Definitely this, so long as there is an outlet in the basement that goes to the same power panel as an outlet from the room your router is in, it should work perfectly. They are extremely simple to set up as well, just plug them in and, at most, push a single button on each device to get them to auto-connect to one another. Prices are not bad either, below $30 for a 200Mbps kit.
powerline
Intel i7-4790K Processor, 32 GB Kingston HyperX Fury DDR3-1600 RAM, ASUS Z-87 Pro Motherboard, Corsair RM 750 PSU, 250 GB Samsung 840 EVO SSD, 2 x 1TB Seagate Barracuda HDDs, ASUS GeForce GTX 970 STRIX GPU, Corsair Carbide 500R Case, AFT Pro-77U Card Reader, Dell UltraSharp 24 Monitor – U2415, Logitech HD Pro Webcam C920, Windows 9 (Windows 10 with StartIsBack++)
  • 2 weeks later...
Either Powerline & Router like everyone else is saying or just drop some wi-fi extenders about.
CPU: Intel Core i7-7700 GPU: NVIDIA GTX 1070 Cooling: N/A  Motherboard: N/A  Ram: 32GB
HDD: 4TB RAID 1 Array (two 4TB)  PSU: N/A Case: N/A OS: Windows 10 Mouse: Something Something Logitech
Keyboard: Razer Blackwidow 2016 Headphones: Audio Technica ATH-M40X Speakers: ??? Monitor: 2 x HP 22cwa  Phone: OnePlus 3T (T-Mobile Network)
