Don't ask why, its not for me its for some customer. Anyways i was thinking that a noctua nh d14 will be fine and ill just take off the fans or is there something better. liquid cooling isnt an option.
case: zalman z5
Listen if you care.
https://linustechtips.com/topic/44577-best-passive-cpu-cooler/
Thermalright Silver Arrow is great as a passive cooler.
Edit: Also the Nofan CR-95c IcePipe is great, if you can fit it
Bloody hell that second one is massive.
Listen if you care.
https://linustechtips.com/topic/44577-best-passive-cpu-cooler/#findComment-584653
It's a planet! o.o
Slicks whole hand could fit in it
Listen if you care.
https://linustechtips.com/topic/44577-best-passive-cpu-cooler/#findComment-584788
