Computer Has Power but Will Not Start
Go to solution Solved by Rune,
Something might have ratled out when you moved it, unplug everything and then plug it back in.
Took everything apart and plugged it back in already. No change.
The only thing I can come up with is that somehow, somewhere between the 24 pin connector and the 8 pin cpu connector, something broke. If I paperclip the psu 24pin cable all of the components spin up fine.
Hello. I just moved house and brought my computer with me. Upon hooking it back up, the motherboard displays the standard green power LED, but will not power anything on. Case fans, hard drives, water pump remain off. I tried jumping the power switch pins as well to see if the case button had broken, but no difference. Any ideas? I'm really stumped on this one. Motherboard is an Asus Z97 Sabertooth Mark 1.
Edit: Detailed necessary setup:
Intel 4770k
Corsair Vengeance 8gbx2
Corsair HX850
Corsair 900D
https://linustechtips.com/topic/445559-computer-has-power-but-will-not-start/
