http://ca.pcpartpicker.com/p/8ZCVK8
PCPartPicker part list: http://ca.pcpartpicker.com/p/tLzxJx
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($84.99 @ NCIX) <-------overclocked to 4.2 GHz
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($57.98 @ DirectCanada)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR3-1866 Memory  ($56.71 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.98 @ DirectCanada)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($56.25 @ Vuugo)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($74.99 @ NCIX)
Other: GTX 580 kijiji ($90.00)
Other: kijiji monitor ($50.00)
Total: $530.90
Generated by PCPartPicker 2015-09-05 17:35 EDT-0400
do you guys think that this will be suitable for source 2 games
https://linustechtips.com/topic/444729-build-planing-help/
The only thing I'd suggest is at least an i3 because it will help prevent frame droppings and improve the overall performance.
Also, if it's important to have a little more wattage, this is a solid PSU unit for an alternate part from a good brand.
http://ca.pcpartpicker.com/part/rosewill-power-supply-arc650
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/444729-build-planing-help/#findComment-5960040
Total: $530.90
Where do you live or do you know any physical computer stores around you? Reason I ask is because some stores bundle the cpu and motherboard together for a savings. You should upgrade that CPU. Everything else looks good. Good psu, and everything. In the future you should buy an SSD.
https://linustechtips.com/topic/444729-build-planing-help/#findComment-5960239
Whare i live there are no pc shops nearby except best-buy and stuff like that
https://linustechtips.com/topic/444729-build-planing-help/#findComment-5960493
I use to drive 40 minutes to get to a good computer shop where I use to live. You sure none are around? For your case though I would suggest looking at AMD processor. You can get a fx 6300 a 6 core processor which works well, fx 4350 a quad core. I do recommend AMD processor for a budget build. A 6300 will perform better then a pentium and i3. The fx 4350 should perform better then a pentium. If someone was spending more money I would suggest Intel and at least an i5. For you, go amd. In the future you can always upgrade to a better AMD processor like a fx 8350 or buy a new mobo and processor.
https://linustechtips.com/topic/444729-build-planing-help/#findComment-5965283
