Case : H440
CPU : i7 4770
Motherboard : MSI krait z97
GPU : Gtx 980 ti
Ram : 16GB
Hello, I currently have Corsair H100i with me but I didn't installed it because one of the "tech guy" said that It's not recommended for this case (H440). They said I could install but wouldn't recommended to do so.
If it's not recommended, I'll get a air cooler that's easy to install and quiet yet efficient.
My current idle temp is 64c and load is 94c.
But GPU in the other hand is 53c and 79~85 under load (EVGA Superclocked w/backplate Gtx 980 ti)
Any recommendation for aircooler that'll fit freely and easy to install for this case will be greatful. Thanks
https://linustechtips.com/topic/443092-cpu-cooler-choices/
