980ti SLI Issues
Go to solution Solved by PCEnthusiastLuke,
what are your PC specs? Motherboard especially...
do you have an SLI bridge?
Yes, I use the one that came with the first 980ti, I have not tried the other one however... I'll do that now
Recently I purchased and installed a second 980ti to my system, and up until today I have had no troubles with it.
The second GPU has been in my system for a week, and today my PC will not boot.
I installed a speaker to my motherboard and received a beep code similar to 1 long beep, followed by 3 shorter beeps... After some research I found that this is a video card error! :(
Where do I go from here to try and fix the problem?
Regards,
My system has two 980ti's, I'm making up for my small gentials
https://linustechtips.com/topic/442449-980ti-sli-issues/
Test both GPU's on their own, in both PCIe slots
Just done this, moving each graphics card into each slot on their own produces the same results on all 4 occasions.
Atleast provide some additional information about your system...
We can't do anything with "lolz it dsnt wrk, halp".
I have an Intel Core i5 4690k @ 4.4GHz, 850w PSU, MSI gaming 7, 16GB corsair RAM, 2 x 980ti
https://linustechtips.com/topic/442449-980ti-sli-issues/#findComment-5929979
Regards,
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/442449-980ti-sli-issues/#findComment-5929980
https://linustechtips.com/topic/442449-980ti-sli-issues/#findComment-5929989
