I'd consider this a "Console Killer" system because personally I got the price down to, wait for brain fart, 326$ USD!  The specs are below. disclaimer:  I have 2 1tb WD Caviars with green power that are just layin' around so that's like 50 usd off right there.  All prices are in USD, United States Dollar.  These are New prices and are unused products so you could get POTENTIALLY cheaper prices on these if they are refurbished or used.
Case:  Fractal Design Core 1000, Price: 18.99$
CPU:  AMD X4 860X, Price: 74.99$
GPU:  750 Ti ASUS OC, Price:  104.99$
RAM:  Crucial Ballistix Sport 2X 4GB, Price:  42.99$
Motherboard:  GIGABYTE GA-F2A68HM-H FM2+ AMD A68H 4 x SATA 6Gb/s USB 3.0 HDMI Micro ATX AMD Motherboard,  Price:  45.99$
Power supply:  Thermaltake TR2 700W 80+ Bronze Certified,  Price:  39.99$
So can you help me with finding parts that could be even cheaper?
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/442376-pc-budget-build-help/
This is cheaper than both the Xbox One and PS4.  I also have various peripherals laying around so all of those expenses are gone but you could turn this into an HTPC and it will work just fine.
https://linustechtips.com/topic/442376-pc-budget-build-help/#findComment-5929122
