Hey i installed cm 12 and now i cant use a couple of apps and i want to revert to normal android.
i cant seem to install obd or fastboot on my computers so how can i do it without them?
i will probably not respond as fast so just write now and after i have slept for an hour ill come back and read.
https://linustechtips.com/topic/442331-nexus-5-help/
what apps couldn't you use?
https://linustechtips.com/topic/442331-nexus-5-help/#findComment-5928637
Its two norwegian apps called viaplay and vipps. Viaplay is a movie streaming service like netflix, hulu and hbo combined. Vipps is a banking app
so basically those apps won't run on a rooted phone
you could try root cloak..see if the apps will run once you got that
https://linustechtips.com/topic/442331-nexus-5-help/#findComment-5929700
