Recap on my Issue
I recently Bought a new Case to Replace my Cooler master 330U
I Bought a Corsair 760T and since i moved my components when ever my PC is on it Interferes with Both of our TV's
any TV Channel Owned/Broadcasted by the Seven Network(Channel 7,7Mate Ect) and any TV Channel owned/broadcasted by the Nine Network (Channel 9, GO! ect)
goes all Glitchy, Lags, or sometimes cuts out
ANything owned by the Channel 10 Network and the ABC is fine and crisp with no problems
PC Specs
B85 Pro Gamer
GTX 980
i7 4790 (Not a K series)
TPlink 300mbps wifi PCI card
Corsair 760T
8GB Kingston ValueRAM
Antec HCG-520 ( 520W High Current Gamer) Continuous Power
Corsair H105 CPU Cooler ( Bought same time as 760T)
What do i do?
If i turn my computer off the problem goes away
The Computer is In a different room to both TV's
both tvs are directly across the house from each other(One at the front and back)
I never had this problem with my 330U
Please help
Same problem with Channel 7 over here in WA, they broadcast on a frequency that's easily interfered with by lots of equipment.
I can have my PC running on the other end of the house and it causes issues sometimes with the TV.
Beefy ferrite bead/chokes (clamp over power cable) usually reduces the problem (if not eliminate it), try and get the biggest you can and remember to loop the cable through it.
I got some, it seems it fixed it, one on both ends of Computer Power cable
I'll let you know how long it keeps the signal good sometime in the Future
The Ferrite Beads Did and Didn't work
The issue i have is with 2 Networks Everything owned my Channel 7, and 9
Channel 7 was solved with Ferrite Beads but i still have a issue with channel 9
THIS ISSUE STARTED WHEN I GOT A NEW CASE!
CASE IS IN THE SAME SPOT AS MY OLD CASE
I HAD NO ISSUES BEFORE I GOT A NEW CASE
THE  DAY I GOT A NEW CASE THESE ISSUES STARTED
THE PSU IS A ANTEC HCG-520
I got 8TB of storage, all SSD's no HDD's, Lots of money ;)
https://linustechtips.com/topic/441138-tv-signal/
