Hello , need help couldn't Pick PSU
Hi Guys i'm going to build a pc soon but every PSU available in my country i read it's not really good
i wanted to get ThermalTake Smart SE 730W But in reviews i've read this
  • Loose voltage regulation, Bad results at Crossload tests, 3.3V rail out of limits in the second Advanced Transient Response test, Cannot deliver its full power at >40°C operating temperature
and i'm not planing for SLI , then i searched for Corsair VS650 and i've read a comment that it's not really do its job , so which one i should take
https://linustechtips.com/topic/440479-hello-need-help-couldnt-pick-psu/
Got XFX PSU's over in your country?
Hey bro i like yo *vomits on you*
SpOOkY  - Intel Core i7 4820K - Sapphire Radeon HD 7970GHZ Toxic Edition 6GB - 16GB Corsair Vengeance 1600Mhz - Gigabyte X79-UD3 - EVGA Supernova G2 850W
My GrApHiCs DeSiGn TeAcHeR Is GoInG To bE sO MaD
No Bro :( , and we can't buy online here in Algeria , also i need to go to another city to buy my pc , tell me if Thermaltake Smart SE 730W is good choice , cause its price acceptable somehow
hmm i just couldn't chance it on the Thermaltake unit, especially for SLI. and the VS650 isn't a paticuarly great PSU ethier.
Do they maybe have Superflower units from where you are buying?
Check out the PSU whitelist in my sig to see if anything good there can be found in your country.
