This me simply asking a question, I don't not play to watercool yet and my system would need to upgrade first anyways(I don't have any money right now) but would it be possible to do a custom loop in a compact case like the S340 with like a 140mm rad in the rear and 280mm rad in the intake. Would the temps be good and where would I place the reservoir would I have to remove the cable management bar?
It would just be cooling the CPU and a single GPU
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/440183-custom-loop-in-nzxt-s340/
The S340 isn't the best case to do a custom loop in just due to the mounting options, if you want to just go with say a CPU loop a 280mm in the front would be good but not having some more dual or triple mounting locations make it less ideal.
https://linustechtips.com/topic/440183-custom-loop-in-nzxt-s340/#findComment-5900887
