External DVD drive causes boot issue!
Solved by Speedbird,
I updated the bios from 2405 to 2407 but that didn't seem to help. Is there anything else I should update from the driver list? I wasn't a 100% sure what each of the different drivers did and I didn't want to risk bricking my board...
Don't worry, the worst that could happen by installing a wrong driver is a broken Windows install, and you can fix that by reinstalling Windows.
Anyway, this is probably a compatibility issue with the BIOS and the optical drive. There's nothing that can be done except wait for a new BIOS release to come out and hope that it fixes the problem.
