Yeap, 1, the performance almost doesnt change if you are not using some integrated GPU.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/439489-1stick-or-2stick/#findComment-5892198
I got one 8gb initially and then added another 8gb stick.  just in case I ever really decide I need 32gb
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/439489-1stick-or-2stick/#findComment-5892221
Just buy the 1 stick.
You can have room for later upgrade!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439489-1stick-or-2stick/#findComment-5892235
About the drive on that Build, Don't get that, If you are using that drive for playing games.
WD Greens are meant for storage only purpose. They perform poorer. But reliable.
Get Toshiba HDD or Hitachi DeskStar drive.
https://linustechtips.com/topic/439489-1stick-or-2stick/#findComment-5892245
for playing games it doesent drop frames or anyithing so i think this will be good and im also geting 128gb kingston ssd
https://linustechtips.com/topic/439489-1stick-or-2stick/#findComment-5892336
Nothing about framerates, The loading time will be longer that is all.
Also if you're getting Kingston SSDNow V300 SSD, Please don't. It's a piece of crap SSD.
Buy a Samsung 850 evo or Crucial MX100 if you can. They're good for the price! :)
https://linustechtips.com/topic/439489-1stick-or-2stick/#findComment-5895569
