TV Signal Issue
Go to solution Solved by infamous_last,
Same problem with Channel 7 over here in WA, they broadcast on a frequency that's easily interfered with by lots of equipment.
I can have my PC running on the other end of the house and it causes issues sometimes with the TV.
Beefy ferrite bead/chokes (clamp over power cable) usually reduces the problem (if not eliminate it), try and get the biggest you can and remember to loop the cable through it.
I recently Bought a new Case to Replace my Cooler master 330U
I Bought a Corsair 760T and since i moved my components when ever my PC is on it Interferes with Both of our TV's
any TV Channel Owned/Broadcasted by the Seven Network(Channel 7,7Mate Ect) and any TV Channel owned/broadcasted by the Nine Network (Channel 9, GO! ect)
goes all Glitchy, Lags, or sometimes cuts out
ANything owned by the Channel 10 Network and the ABC is fine and crisp with no problems
PC Specs
B85 Pro Gamer
GTX 980
i7 4790 (Not a K series)
TPlink 300mbps wifi PCI card
Corsair 760T
8GB Kingston ValueRAM
Antec HCG-520 ( 520W High Current Gamer) Continuous Power
Corsair H105 CPU Cooler ( Bought same time as 760T)
What do i do?
If i turn my computer off the problem goes away
The Computer is In a different room to both TV's
both tvs are directly across the house from each other(One at the front and back)
I never had this problem with my 330U
Please help
I got 8TB of storage, all SSD's no HDD's, Lots of money ;)
https://linustechtips.com/topic/439085-tv-signal-issue/
PC Specs
B85 Pro Gamer
GTX 980
Corsair 760T
What do i do?
Please help
satellite?or cable?
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887080
Neither im in Australia, we don't have that, We have Foxtel ( its like Cable)
i just have standard TV since we don't watch it as much as we use to
looks like its IPTV
so its probably not directly the pc
its probably the modem or router causing interference on the line
We have Foxtel in Australia,(Paid Service)
but i dont have it, Because its Shit
i have normal PAL Format TV
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887112
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887124
*Crys*
Im not the only one :)
like WTF Channel 10 is HD as hell without a isse but channel 9 and 7 get effected
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887127
I think the case is the issue :(
i had no issues before i got my 760T
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887131
Where can i buy some good ones?
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887168
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887178
Maybe WiFi Frequency interferes with the TV-Signal. You should try a LAN-Cable.
I successfully hacked 127.0.0.1! Now I cant turn on my computer :/
6700K - z170 Pro Gaming - Samsung 850 Pro 256GB - WD Black 1TB - WD Green 3TB - External Hard drive 3TB - Zotac GTX 970 Amp! Core Edition - Fractal Define R5 - RM650 - Razer BW Chroma - Roccat Tyon Lasermouse
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887229
Modem is in another room
HOW MANY TIMES DO I HAVE TO SAY IT
THE ISSUE STARTED WHEN I GOT MY 760T
WIFI Frequency cant do a thing, ive had the same Router and TV for the past year with no issues
Thing dont just go Fuck you, ill mess with your shit
day before i got 760T, No Issues Ever with TV singal
very Next day(Day i got 760T) Issues everywhere
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887245
Did you change PSU to?
The ones I'm using came with the some other equipment I bought, but JB Hifi, Jaycar or Dick Smith etc should have some, not sure if it's something normally carried by PC stores.
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887424
No ididnt buy a new PSU
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5887669
I got some, it seems it fixed it, one on both ends of Computer Power cable
I'll let you know how long it keeps the signal good sometime in the Future
https://linustechtips.com/topic/439085-tv-signal-issue/#findComment-5893930
