Hi again everyone,
About half an hour ago I posted the question about the best way to test the temps of my CPU and I got the advice to use Aida64, so I did.
I wanted to know if anyone can tell me whether these temps are good for a Xeon E3-1231v3 processor cooled by a CM Hyper 212 plus.
Under load (after stressing for 15 minutes):
Idle (+/- 3 minutes after stopping the stresstest):
The temps are a little lower now on idle (30-38 degrees depending on the core)
Thanks :D
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/438834-my-temps-ok/
Yeah those temps are fine. I wouldn't be comfortable with 85°C +
Case Phanteks Enthoo Evolv ITX | Motherboard Asus ROG Strix Z270i | CPU Intel i7-7700K | RAM Team Vulcan 16GB DDR4 | GPU Geforce GTX 1080 Ti | Storage Crucial MX300 1TB M.2 | PSU Corsair RM750x
https://linustechtips.com/topic/438834-my-temps-ok/#findComment-5883506
youre good, 70 at load is ok
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/438834-my-temps-ok/#findComment-5883522
for xeon its pretty high temps actually, most xeons run at 40-50*C max under load, but no wonder coz ur using a hyper212... who in the heck uses a hyper 212 on a xeon... get some proper cooling on that xeon... wtf ^^
I'm sorry  :blush: !!!
I'm broke as hell, and I need to upgrade my graphics card soon. So getting a decent cooler will not happen in the next 6 months.
I actually figured it wouldn't really matter since I won't be overclocking it (duh), and I'm guessing it's still better than the stock cooler.
My System:
https://linustechtips.com/topic/438834-my-temps-ok/#findComment-5883768
