Hi,
Does it matter what type a Ethernet coupler speed says it will run at?   I'm looking at some on eBay and they say they are cat5 but claim they can run a cat5e or cat6 cable?  If I connect a cat5e or cat6 cable to a cat5 coupler will it slow down speed of the faster cables to cat5?   Thanks.
David
https://linustechtips.com/topic/436202-ethernet-cable-coupler-speed/
Hi,
David
It should be the same or higher than the rated cable your using to ensure speeds and quality in the system, since they have the proper shielding.
http://www.amazon.com/Ugreen-Network-Keystone-Coupler-Female/dp/B00A30FDS6/ref=sr_1_2?ie=UTF8&qid=1440365260&sr=8-2&
Ok thanks for the advice!
David
