Question about LED Strips
Well that's good news. I'm not the best at soldering, but soldering a few places per strip shouldn't be too hard. Is there a good tutorial for multiple 'zones' that you would recommend, or do you think I will understand what to do once I see it in person?
I don't really know any tutorials, I learned how to use led's mainly by myself. When you buy them they are usually grouped as 3 in the strip, and at any side of the 3 you will see a dashed line where you can cut. If you get leds coated in resin just peel of the resin from the copper connectors to solder.
EDIT: Just when measuring the lenght of wire to extend the leds, cut more then you need.
Pic how to cut. And as you can see you solder wires in between the copper connectors. I like to use colored wires for easy use.
