I am bbuilding a pc for the first time and i put everything together it doesn;t start up the fans spin and i feel some heat but my monitor will not light up
My build
CPU-i54960k
Mobo MSi PC mate z97
psu-corsairtx750
Ram-2 gskil 1 gig (ram old i know build using these until my new ones arrive)
Thank you
should i put my graphics card in?
and my hard drive is old has has items on it
https://linustechtips.com/topic/435005-first-time-building-a-pc/
My build
CPU-i54960k
psu-corsairtx750
Thank you
Make sure everything is connected properly and securely.
https://linustechtips.com/topic/435005-first-time-building-a-pc/#findComment-5830549
That CPU doesn't exist.
He probably switched the 9 and 6. I think i he means the i5  4690k
CPU: Intel i5 4690k @4.3GHZ COOLER: Arctic Freezer Pro 7 Rev 2  MOBO: Asus Z97-E RAM: Kingston Hyper X Black 2x4GB GPU: Soon to be EVGA 1070! Case: Fractal Define S Storage:PNY 240GB SSD, 500GB Seagate Barracuda PSU: Corsair RM650x
https://linustechtips.com/topic/435005-first-time-building-a-pc/#findComment-5830561
well safley plug in your graphics card and then put the display cable into the graphics card and please be sure the monitor is on
i hope he doesnt have a old pci graphics card or AGP and literally tries to push it in a pci express slot... xD haha
https://linustechtips.com/topic/435005-first-time-building-a-pc/#findComment-5830639
