Is there a feature in Sketchup that allows you to export an animation to another computer for rendering?
I am trying to quickly render something for someone as it will take a long time on their current setup. Any help much appreciated.
CPU: AMD FX-8350 | CPU Cooler: H80i | Motherboard: Asus M5A99FX PRO R2.0 | RAM: 8GB Kingston Beast 1866MHz
Case: Define R4 | GPU: Gigabyte GTX 780ti | PSU: Corsair CX600M | SSD: 250GB Samsung 840 EVO
.... and a Partridge in a pear tree!
I've never used sketchup, but I assume you can save your project? Take that file and put it on the other PC together with any files you may have involved (make sure to put them in the same directory) and it should work.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
He is using Sketchup Pro which I don't have
You will have to just stick with the long render, I don't think there is way you can use multiple PC's to render 1 project at least not with Sketchup
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
