Hey,
Im following linus' advice to buy a bulk of charging cables, and put them anywhere.
(I have Galaxy S3, S2, S5, Ace, and Nexus 4 at home)
Do I need "certified" samsung cables, or are these gonna do the trick? (without any danger to the device)
I have plenty of power plugs, but not many cables...
Also, I have an iPhone 5. Do I need a cable from Apple, or these will do? I have the power plug (A1400), so does the cable matter?
(Will the iPhone alert me: "unoriginal charging cable may harm your device")
Thanks!
Edited by Amit Moryossef
https://linustechtips.com/topic/433637-charging-cables/
Hey,
I have plenty of charging power thingies, but not many cables...
Thanks!
They should work no problem Ideally cables with a wire gauge of 28/24 AWG would be best to carry higher current charging since they have larger wires for the power:
http://www.monoprice.com/Product?c_id=103&cp_id=10303&cs_id=1030307&p_id=5457&seq=1&format=2
https://linustechtips.com/topic/433637-charging-cables/#findComment-5811786
Thanks! You wont belive it, but the same cable costs (lowest price) on ebay 3$ + 24$ shipment to Israel :( Ill get the slower ones then.. (1$ + free shipping)
https://linustechtips.com/topic/433637-charging-cables/#findComment-5811860
