So the NZXT logo at the bottom of the window lights up. I was wondering if the LEDS were just a strip, or tailored to the letters; I am planning to Laser Cut an acrylic panel to go over their with my (conveniently 4 lettered) build name, Orca (B/W with blue accents). Judging from pictures, it looks like a strip, but not 100% sue. what do people think?
https://linustechtips.com/topic/433373-nzxt-h440-lights/
imo looks like a strip on top of the letters shining down. but dont take it from me I suck at modding etc.
Specs: i7-4790k with Thermaltake Water 3.0, EVGA GTX 970, MSI Z97 Gaming 3, Kingston HyperX 2x8 DDR3 1600Mhz, SSD Boot Drive/1TB HD, CM Storm Stryker, EVGA Supernova G2 750W
Peripherals: SS Rival, HyperX Cloud, G710+
https://linustechtips.com/topic/433373-nzxt-h440-lights/#findComment-5808527
I took my h440 apart not too long ago to do some painting and if I remember correctly the leds for the logo are mounted onto a plate that screws down to hold the letters in place. The letters are kind of sandwiched in-between the larger black part and the plate with the leds. So to answer your question, I would say a little bit of both?
I think what you want to do is perfectly doable and you could easily figure out a way to use your own leds if that's your plan.
https://linustechtips.com/topic/433373-nzxt-h440-lights/#findComment-5809660
