NAS help please.
Solved by Captain_WD,
Hey guys at the moment I am running Asustor AS 202TE NAS with 2 2tb wd Reds in raid 0. Now I have a problem at the time I didnt plan on storing much on the NAS maybe movies music so I thought i will RAID 0 them. It hit me that I don't want to loose everything I have downloaded.
So I am hit with a proble. How do I back all of this up? Do I which I have planned to do buy a bigger NAS the big brother to the Asustor AS 202TE with 4 bays and run 2 3 tb wd reds in raid 1 move all my data from the first NAS and then have the first NAS for something else?
Other solution I have two 4tb wd blacks I could use one of them to back up all of that NAS to a single drive or use an external ? What do you guys think?
Hey there Sniper Xls,
Having two WD Red drives in a mirror mode should give you redundancy and better safety in case either of the drives fail. I would recommend that in terms of data safety. A single large drive directly connected to the NAS should be the cheaper option, using it with a simple enclosure, SATA to USB cable (with an extra power source) or a docking station.
Captain_WD.
