Here's a tip. If you don't know why you did something, it probably doesn't belong in a review. (Hint: League of Legends)
That was meant as in: we allmost certainly knew it wouldn't work, still tried.
Maybe we should have phrased that somewhat different.
The thing is though, no one is ever going to use it for League of Legends, so whether or not it actually works for it is fairly irrelevant. You should rather focus on how well it works in games where you would actually use it, say racing games. How good the triggers, sticks and especially buttons feel when playing, what the surface is like and generally how good the build quality is.
I stopped at Call of Duty...
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
