Im using MSI Command Center v1.0.1 to control all of my bitfenix spectre pro fans that are plugged into the fan headers on my z97 gaming 5 motherboard. I go to advanced settings, and save a fan profile, and then edit it in notepad so that I can make the fans spin lower than 50% at idle, or even turn off. However when I turn the system off and on again it goes back to using the defaults that are extreamly overkill for the amount of cooling I need out of them at idle, and they become loud. Does anyone know how to change so that MSI Command Center loads a custom profile on startup instead of defaults?
Thanks
https://linustechtips.com/topic/432401-msi-fan-settings/
