Hi Guys,
I’m looking for your expertise on this build.
1) I don’t have a solid budget at the moment but I’m thinking about £800 if it can be done for less then great.
2) The main/sole purpose of this PC is for cloning and imaging hard drives.
3) It needs to have multiple hot swappable bays and a large amount of internal storage in RAID for the images.
4) The budget isn’t including an operating system or the storage HDDs because I already have these. Also I don’t need any peripherals.
Basically I just need a solid build that isn’t overkill, and that won’t need upgrading for a good few years.
Thanks in advance.
https://linustechtips.com/topic/432181-imaging-and-cloning-pc-build/
Reckon you'd need an Asus WS board for enterprise features trouble is these are quite expensive watch JJ's vids on youtube plus a big case reckon you wont need a super processor so could just go with i5
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
I was looking at a build Linus did for a NAS and I was wondering if something similar would be suitable for my cloning PC.
8 Bay Silverstone SST-DS380B Premium Small Form Factor Case
ASRock C2750D4I Mini ITX Avoton Motherboard
Does anyone know if this motherboard/CPU would be ok or does anyone have a recommendation?
