I've built a new pc and it wont post, when I push the on button or short the connectors its still dead.
The psu im using is the corsair cx 600m, I dont think it has a "0 db" feature, so the system fan should be spinning regardless, right?
Even if the cpu is dead, my system fans should be running if im not mistaken.
What can i do to find out what component is failing?
(I've built 2 systems before)
https://linustechtips.com/topic/432100-possible-dead-psu/
Did you flip the thing on the back of the power supply
Did you put the power button FP connector on backwards
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5792769
Would it be too much of a hassle to grab a PSU from one of those other computers, or are you not with them anymore?  Then you could see if the PSU really is the issue.
I REALLY dont want to do that, i was hoping somone could confirm my theory regarding the fan spinning
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5792850
Make sure the front panel connectors are in properly :)
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5792858
If hes tried shorting the connectors then the orientation of the front panel connectors shouldn't mean anything really.  You might be able to short those two pins on the 24-pin to try to run a fan off the power supply without the motherboard (kinda like they do when filling a water cooling system).  That's the easiest thing I can think of.
"You should look up common sense and add it to your vocabulary." - dougdangger 2015
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5792987
Will the system fans/ cpu fans run without a processor? In that case i have located the problem to 2 areas, the psu or the mobo
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5793029
I'm not sure how that's dealt with because I'm not the techiest of people, but when people fill water cooling loops (and test them) they use a special adapter for the 24-pin plug on the PSU to trick it into thinking it's on and allowing the pump to well, pump, without having the risk of a leak shorting out components (as the system would technically still be off)
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5793049
(image)
are you runing your system with out water in a loop or this isnt your picture?
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5793148
Not my picture, just googled to get a picture of the adapter so I could show him what I was talking about.
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5793167
Ok, guys. I have solved the problem. I shorted the wrong pins. I looked up the pins in the manual that came with the moterboard, but they had listed wrong pins or something. Because when i shorted some random pins on the other side of the " place where front panel connectors go" it suddenly booted. They must have sendt me the wrong manual
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5793481
You should mark this thread as solved.
It's not a race to the bottom.
https://linustechtips.com/topic/432100-possible-dead-psu/#findComment-5793556
